B4 vs B4 II
Fretless
B4 vs B4 II
Message par Fretless »
Pour les utilisateurs de B4 II ayant utilisé un B4 tout court, quelles sont les améliorations apportées sur la version II (hormis les banques supplémentaires).
La simulation Leslie a-t-elle été améliorée ?
Quid du rendu de la simulation lampes et cabinet ?
Bref,
Le passage à la version II est-elle intéressante lorsque l'on n'est pas intéressé par les sons autres que Hammond ?
Merci de vos avis !
Samuel Caton.
"Tous chez Huggy les bons tuyaux !!!"
B4II UPGRADE DESCRIPTION
Upgrade to B4 II for Even More Great Organ Sounds!
The Native Instruments B4 software organ broke new ground when it was first released in 2000 and was an instant success, reproducing the sound of the legendary B3 and its rotary speaker cabinet with unmatched accuracy. Its expressiveness and immediate playability continues to amaze even the most experienced organ players. Now B4 II raises the bar considerably, generating a much wider sonic range and a far richer, even more authentic sound.
Native Instruments B4 II Software Organ at a Glance:
New amp and cabinet models and reverbs
Incredibly accurate and detailed organ sound
Instantly playable presets and great feel
The latest version of the award-winning B4 software organ sees the addition of many extra components. A tube amplifier and a selection of classic speaker cabinets offer you greater freedom of expression. Spring and studio reverb modules lend the sound more depth and atmosphere. From silky soft to relentlessly rockin', the B4's sound is stunningly precise and more versatile than ever before.
From the drawbars, the vibrato and chorus to the tube distortion and rotary speakers, the B4 II delivers the sound of the original in incredible detail. The cross-talk between the tonewheels is adjustable and 11 additional tonewheel sets are also included: "Cosmetically age" the B4 II or transform it into a Farfisa, a Vox Continental or an Indian Harmonium.
The B4 II is instantly playable. Its convenient Preset Manager coupled with a large selection of presets offer a wide range of styles. The new bass pedal legato and string bass features make using the foot pedals easy: a walking bass has never been simpler. The B4 II is a rounded, enthralling and easy-to-use software organ that instantly delights. Start playing and you won't stop!
Fretless
Thanks Michael !
Samuel Caton.
Désolé de mon copier/coller sans même un petit mot, mais le soir ma femme rale quand je traine trop devant l'ordi....alors je fais au plus vite pour les messages ! :wink:
C'est en anglais, mais on comprend assez bien. Je n'ai personnellement connu que la version 2, et je peux t'assurer qu'elle déménage. Je l'aime beaucoup. La compatibilité avec mon système est fantastique (xk-3 + lower générique + pédalier 13), et à part un problème de tirettes pour le lower que je n'arrive pas à régler, il m'arrive fréquemment de jouer sur le B4II dorsque j'ai envie d'entendre un son "crunchy" pour du blues ou du rock.
Je crois que la principale différence avec la première version se fait là, au niveau des "lampes" et des cabines.
Tu peux télécharger la démonstration. Elle est limitée dans le temps je crois, et tu ne peux sauvegarder tes paramètres, mais elle est pleinement fonctionnelle, musicalement.
Fretless
Merci !
J'ai longuement essayé le B4 chez mon oncle. C'est très sympa en effet. Le B4 II doit être très bien. Avec la télécommande dédiée disponible en option, on doit bien s'amuser et cela laisse u peu de budget pour les autres sons de claviers Vintage (le EP en particulier).
Merci de tes réponses en tout cas.
J'essaierai la démo. Je risque de craquer ...
Samuel Caton.
Red Firebird
Message par Red Firebird »
J'ai upgradé il y a qq mois et effectivement les sons crunch sont vraiment bien et la simu de Leslie plus riche. Les simus d'ampli sont sympa aussi, ça permet de retrouver des sons comme ceux de Brian Auger par ex. Il y a plus de possibilités en Midi dont un Learn. Les sons de Farfisa et de Vox marchent bien aussi, c'est un chouette bonus.
Cédric
www.tone.free.fr
Fretless
Merci Red Firebird.
Samuel Caton.
